cv6 - Notice Countdown - Adds the possibility to add a day countdown in a notice.
This AddOn allows you to add a day countdown till the selected end date in the page criteria in the notice. You can choose between some designs or create your own.
Additional Setting:
You can edit the custom style in the Style Misc Section.
How it can look like:
As the target the before page criteria is used, so the counter should never be a zero.
If the page criteria can't be found, it...
