Wutime - Limited Guest Viewing Pro
Wutime - Limited Guest Viewing Pro 2.0.4
Wutime - Limited Guest Viewing Pro - Dramatically increase forum registrations by 200% to 300% by limiting guest views
Wutime - Limited Guest Viewing Pro Dramatically increase community registrations by 200% to 300%
Fully featured system to limit the number of content pages your guests can view before being forced to register. It also supports a nag system to warn users that they’re on a limited number of views before having to register.
Proven method of increasing forum registrations without negatively affecting SEO or annoying your visitors. You control how much a...
xenDome updated Wutime - Limited Guest Viewing Pro with a new update entry:
1.9.17
  • ADD: Early exit on notice render if logic not required
  • ADD/FIX: Missing JavaScript function for "Registered Users Breakdown" statistics (stat previously always showed empty, now fixed)
  • FIX: Remove "recursive" SQL reliance for "Notices" statistics so it runs with MySQL 5.7+
  • FIX: Remove never used statistics action for "connected accounts" statistics
2.0.0
  • ADDED OPTION: Custom Add-on Controllers Patterns or Names for addon integration: allows namespace wildcarding or specific controller names to be added
  • ADDED OPTION: Simulate guest experience while browsing as an administrator; Live preview of guest notices on the front-end, Only visible to administrators
  • ADDED OPTION: Display Current Controller Name in Page Header (Debug Mode); helps identify controllers on the front-end for integration with custom...
2.0.4
  • New: Sticky Warning on Scroll: When enabled, the warning message will “stick” to the bottom of the screen after the user scrolls down the page (desktop and tablet only. (default=on) (thank you @Matt C.)
  • New: Sticky Warning on Mobile: When enabled, the warning message will always stay pinned to the bottom of the screen on phones and small tablets (even without scrolling). (default=off) (thank you @Matt C.)
  • Fix: Custom controllers were not auto-redirecting to registration page...
