[XB] Article Preview Message Custom Field Replacement - Replace bland and uninformative article preview snippets with custom field value
This add-on allows you to replace the article preview text with a value from a text custom field that you specify in the forum settings.
This can be useful if you need to display a brief description in the article preview instead of an uninformative post message snippet.
Custom field can be enabled and configured for each article forum separately.
