Xon - Signup abuse detection and blocking
Xon - Signup abuse detection and blocking 1.17.0
[Xon] Signup abuse detection and blocking - Provides a toolkit to reduce signup spam
[Xon] Signup abuse detection and blocking, From (simple) multiple accounts detection to isp/connection fingerprinting with score-based moderating/rejecting logic. These are very effective low-hanging fruit at reducing spam.
Supports migration configuration from the following XF1 add-ons;
  • TPU Spam Detect
  • Alter ego Detector
See the FAQ Known Issues for known limitations. This is not a turn-key solution, and each site may require customization!
For multiple account...
xenDome updated Xon - Signup abuse detection and blocking with a new update entry:
1.17.0
  • Require StandardLib v1.22.0+
  • Improve XF cloud compatibility
  • Re-add XF2.1 support
  • Update Country language/timezone anti-spam option example text to be explicit that is supports wildcards
  • Fix 'Country language - Unknown' did not reliably apply non-zero scores
  • Do not skip country language tests if the country is unknown, instead use XX as the country
