[Xon] Standard Library
[Xon] Standard Library 1.22.6
xenDome updated [Xon] Standard Library with a new update entry:
1.21.14
  • Update to choices.js v11.0.4
    • Fix selected option being escaped twice (Affects MultiPrefix editing a thread prefix)
    • Fix reaching maximum item limit notice is not cleared after removing selections
    • Fix tab => direction keys handling
    • Fix performance regression when loading options after choices.js object creation (Affects MultiPrefix loading per-forum prefixes)
1.22.2
  • Workaround unexpected behavior in \XF::options() and strongly typed property hints (generated by XF CLI command xf-dev:generate-options-stub) which may cause bugs in some add-ons
  • Update choices.js v11.1.0
    • Remove role="textbox" from search input, per a11y practices
    • Add choices.search-kmp.js build, more advanced than a simple prefix match but less complex than using FUSE for search
    • Support <option label="..." /> HTML (not generated by XF natively)
